1 - 20 of 25 Posts
96 k1500 Z71 extended cab, 5.7L, 139xxx miles. New power steering pump and high pressure line. Just did oil and trans fluid a few hundred miles ago. New plugs, wires, cap, coil, and ecm within last year . New starter a year ago. Minor body damage, paint has flaws, rear bumper has damage from PO. Has slight miss, didn’t go away after tune up, so I would assume it’s probably a leaky injector or sticky valve. Feels like it slips into neutral when you get on the throttle hard, never had a problem with it just gets annoying on the highway. Driver’s seat has a few holes/burns/ wear spots, head liner is starting to sag. 4X4 works. 2 inch body lift with 285/75/16's, tires have good tread but are starting to dry rot. $1000 OBO, open to trades, just not vehicles.
With the issues on the motor, do you think this would be an issue when towing? I'm interested, just don't want to get in over my head and end up dropping a new motor in a vehicle.
1 - 20 of 25 Posts
