1 - 9 of 9 Posts
Premium Member
Discussion Starter #1 (Edited)
1995 Chevy Silverado 1500 Heavy Duty. 6.5 L Turbo Diesel with less than 70,000 miles, 4L80E Transmission with less than 60,000 miles, HD Transfer Case with less than 60,000 miles on it. Extended cab with seating for 5. Power windows, Locks, lumbar, tilt wheel, cruise control. HOT heat, 60/40 split bench with easy rear access. Rear seat folds flat (horizontal) or flat (vertical) against the rear of the cab. Has A/C but there is a leak in the A/C system and it will not hold pressure. 3, 12 volt outlets in the cab, pretty much every option for the age except leather. Truck is solid with relatively minor rust. Solid box, great tail gate. Truck has been kept indoors for as long as I have owned it (5 years) and often rinsed off after plowing. Not used commercially for plowing, only around the house.
Western 7'6" Pro Plow with joystick controls and poly cover to help snow roll off plow. New front drive shaft, new front axle actuator, Replacement rear window latches, Extra fuel filter, 2 spare u-joints, 2 spare PMD modules for the injection pump ($500+ each to buy). PMD relocation kit to keep it away from the engine ($700 kit), turbo-master turbo control to eliminate vacuum control, spare glow plugs, boost gauge, 3" mandrel bent down pipe off turbo, 4" mandrel bent exhaust from fire wall back. 2" hitch with Odyssey electric brake controller. New 7 wire plug with switchable fused trailer charging wire. Truck has 265,609 miles on body, but all drive train has less than 70,000 miles. LT 285/75 R16 Yokohama Geolandar A/T-S tires with TONS of life left on them. Truck is an AMAZING plow truck. In 15 years of plowing I have never had a better truck.
$5500 obo
Thanks For Looking!
Premium Member
Discussion Starter #4
What do you have to trade??
trades?
well here is some info on the jeep
-4.6 straker motor with 182k showing on it. runs perfect drive it daily . tanny and 4x4 also work great.
-all custom suspenison lift. 6.5 in rusty's long arm lift. flexs like crazy built professionaly.
-33in pro comp mud tires from 30-40% on black steelies comes with a full size spare.
-all custom built front and rear bumper with hitch and d-rings
-tru trax locker in the rear
-custom half doors
-new ball and u joints brakes are also good
-heavy duty steering box from durango
-medium duty cross members
-glassback exhaust sounds good
-interior in very good shape front and rear seats from a 2001 xj.
-quick disconnects
-slip yoke eliminator
Frame is solid
does have some rust in the floor pans. also includes 2001 rear doors and has matching 01 full power fronts instaled and wired in.
Premium Member
Discussion Starter #6
Price Dropped
Premium Member
Discussion Starter #7
plow season is comming...
Premium Member
Discussion Starter #8
Price dropped...
Premium Member
Discussion Starter #9
sold
1 - 9 of 9 Posts
