Do some research on the steering. I've got a friend that is using a bent drag link and it performs well but it's definitely not the best choice. I'm running High and crossover steering using flat top knuckles on a Grand Waggy Dana 44. It's a pretty simple swap out to get there but it's not cheap. If you really want to do the steering right, you'll have at least the following parts to get.
- Flat top knuckles, milled, drilled, and tapped for studs
- high steer arms for left and right knuckles, there's a good chance you'll either need tall arms or spacers to clear your springs.
- new tie rod
- new drag link
The front end gets pricey especially if you're going to regear it. One thing to consider is the width you want to run. Grand Waggy's will put you at your stock width, which will mean that your tires are going to rub your springs unless you get rims with less backspacing, think 3" or less.
Another thing to consider is that if you want to run bigger tires later, you may as well jump up to a Dana 60 now. i didn't and I wish I had, front ends are expensive to build, why do it twice.
If you are going to run stock springs, get yourself another pack and add a second mainleaf to it with the eyes cut off. It won't make them last forever, but they'll last longer. You could also get saucy and get some XJ rear leaves. Cut the smaller eye off the main leave an sleeve one of your YJ main leafs with the larger eye around one of the YJ eyes. Then you get teh bonus of a second main leaf and also have one eye military wrapped for extra strength.
