4wd.com i got them with no taxes and free shipping. Couldn't pass the deal up.Nice, I've been eyeing those tires and might pull the trigger on a set myself. Where did you pick them up at?
You going 40's? They measure 40" with no air in them yet. I'm betting they'll be in the 41"range full of air. They are 1 1/2" taller than my 39's were (which had 25 psi)Hell yeah that's where I've been looking. Damn good price it seems.
i like the wheels man what are specs on the rims and tiresWell, went out to r+v for the rbor races. Wheeled a bit. Broke a bit, but the truck did excellent. The breakage was my own fault. I crammed the whole week to get prepped for the wheeling, and didn't get to build my bumper like i wanted, but had already cut the brackets off the stock frame horns, so couldn't put the stock bumper back on. I bumped a stump on undertaker and popped the coolant reservoir since the core support pushed back enough to push the coolant tank mounts enough to break it at the bottom neck outlet. We did complete python earlier that day though. Wish i had more pics, but when you're wheeling, it's hard to get out and snap them.
Thanks!i like the wheels man what are specs on the rims and tires
Yup, i got one here too.Hey there friend, found your thread. How do those DIY beadlocks work driving down the highway?
I just helped my brother change the transmission in his Silverado. Wasn't too bad of a job other than the damn thing was seized pretty good to the motorYup, i got one here too.
They're not bad. I've got a bunch of mud in my wheels so there's a vibration. I also haven't been able to drive it all that much since my trans is gone. Hoping to have that changed out by this weekend. I'm also going to put my centramatics back on, and that will help a ton.
Ooh, i hope that doesn't happen to me...if it's loose like it should be, the job will be easy.I just helped my brother change the transmission in his Silverado. Wasn't too bad of a job other than the damn thing was seized pretty good to the motor
Yes sir. I have one in the garage awaiting front and rear output swap to 1410, full rebuild, and twin stick mod along with vss mod to make it work with my 4l60e. Going to be badass to pull front digs. I'm going to be installing individual rear line locks for help with pivot as well.you gonna run a ford 205 behind a ecobox? that was a thought of mine.
