1 - 13 of 13 Posts
Premium Member
Discussion Starter #1
Tonight, when I let the clutch out in neutral, it made a weird noise as it was driving forward....also there was fluid on the ground
I dont think this is good
What kind of fluid? Not being goofy, just checking if its a slave cyl issue or a trans issue.
Premium Member
Discussion Starter #4
Slave cylinder
And it is at the dealer....trans went to shit. Cant get it out of gear, including when it is in Neutral......I drove it 50 feet with it in neutral.
Killer B thinks it is the shift fork, but Silver XJ is gonna dig into it tomorrow
Premium Member
Trans is probally fine, I bet its just the slave or t-out bearing itself.
Were you able to shift it into gear with the engine turned off?
Uh, if he was able to move the Jeep when the shift lever was in neutral, I don't think fixing the slave problems are going to change anything. The slave cylinder controls clutch engagement, not gear selection. He said shift fork. That's on the inside of the trans.
Premium Member
Discussion Starter #8
Well, it looks like the clutch is the first issue...from there they can dig in more
Recovering XJ owner
Dave ... we need to talk.
I'm thinking our tech and Killer B are on the same playing field.
1 - 13 of 13 Posts
