161 - 180 of 186 Posts
589 Fabrication
Discussion Starter #161
Thanks guys. Had a blast at the Mounds with it. Sending my new beadlock design to the laser cutter soon. Then i'll be able to air down a bit more. Should help on the snowy rocks.
589 Fabrication
Discussion Starter #166
I've got a 48 CJ-2A I've been working on.
What are you going to do with the leaf springs you took off?
:nana:
Edit: The original 2.5" leafs....
I've got a lot of springs:
The factory Mahindra rear springs
(4) Rough Country 2.5" YJ springs with shocks
(4) Rough Country 4" YJ springs with shocks
I also have the mahindra rear Dana 44 axle that would be a good swap for your 2A.
589 Fabrication
Discussion Starter #167
Had fun out at Rocks and Valleys a couple weekends ago. Need more horsepower for sure.
Coming up for the next trip:
Rock sliders
Bead locks
Hydraulic hand brake for rear axle
New upper link mounts for front and rear suspension
cage mods
Needs more mouse power under the hood. Maybe later this year.
589 Fabrication
Discussion Starter #172
Got the beadlocks finished up. 32 stainless 3/8 bolts.
Also cut out and welded up a new upper link mount for the rear. Raises the frame side mount quite a bit. It's all installed now and feels a lot better around the yard, so far. Should be a good improvement.
589 Fabrication
Discussion Starter #175
Looked good rolling through the neighborhood. Did you fix the shaft or did it self clearance?
Sent from my SM-T710 using Tapatalk
Thanks. Drives a lot better with the new upper mount. Since the shaft floats in there it only does it some times when it’s in all the way.
589 Fabrication
Discussion Starter #177
Had a bunch of fun up at Drummond Island. Still working on other vids and pics. But here's a quick video at Turtle Ridge.
Roxor did great all weekend. But the powersteering pump is about dead (squeaking in the vid). Looking at upgrades now.
589 Fabrication
Discussion Starter #180
