181 - 186 of 186 Posts
Durango-space-division
I haven't done a ton of research on it, but I see some people starting to use the newer Camaro power steering pumps as they are high volume from the factory. Might be worth looking into.
Low Range Drifter
I'm not sure. I've been looking at Trail-gears pump for an early toyota with a v-belt, but it's pretty pricey at $300.
https://trail-gear.com/steering/trail-gear-power-flowtm-1650-psi-power-steering-pump-for-hydraulic-ram-steering.html
I'm open to other ideas though.
I have a PSC TC pump on the shelf for the buggy. I'll see how it goes. I used to run stock TC pumps on my old jeep and they did fine.
I bought it as part of a "kit", so I'm sure I save $5 on the pump.
589 Fabrication
Discussion Starter #183
Ended up bailing on Bundy Hill and just going to the Mounds since onlyinmyxj22 was hung over. :flipoff:
New tires seem pretty awesome! Incredible traction over the Iroks. A little too much though 🤣 Ended up smoking the clutch on the Woods course, along with breaking the front third member near the pinion support. Nodular case and upgraded clutch are in the mail now.
