Rough Country always strives to design innovative suspension kits that are easy to install, perform great on and off-road and boasts market leading price. Rough Country’s newest suspension kit, the 2.5” Jeep TJ, continues with this company vision and builds on all of these qualities. This complete kit can be easily installed within 2-3 hours without any major modifications and will improve both ride quality and offroad performance. This kit is perfect for a daily driver that wants to run up to a 32” tire, and also wants to increase its off-road ability by increasing wheel travel and articulation. These gains are delivered by combining the new progressive rate coil springs with Rough Country’s highly reviewed performance 2.2 shock absorbers.
The new progressive rate coil springs are the key to giving a lifted Jeep a great ride without compromising stability. This functionality is accomplished by designing the first few coils to compress at 115 lbs per inch and progress to 160 lbs per inch during further compression. The first inch of compression reacts to smaller bumps common with on-road driving and the spring’s progressive qualities react when further compression is required.
Performance tuned shocks are essential to the ride quality and off-road performance of this kit. The Performance 2.2 shocks feature a massive 41.4 mm diameter piston and create a 40% larger displacement than traditional shocks to gives greater control and durability for off-road use. Engineered to mount shaft end down, the enclosed gas shock reduces un-sprung mass but is also capable of being mounted shaft end up.
Designed for vehicles with larger aftermarket tire/wheel combinations, the 2.2 series shock absorber contains an internal rebound disc spring for greater energy absorption during suspension extension. On the reverse side, an external jounce bumper creates greater energy absorption during suspension compression for added protection and durability. The Performance 2.2 series shock features a 17.5mm chrome hardened piston rod with micro pores, 50% larger than standard shock absorbers and is coated in a metallic finish with
two coats of clear.
Keep your center of gravity and your drive train with Rough Country's 2.5" X Series Lift Kit. Progressive rate springs and HD X-Flex arms give you world class articulation. Our 2.2 Performance Shocks ensure premium ride quality on and off the trail.
$949.95
two coats of clear.
- Performance 2.2 Shocks
- Progressive Rate Springs
- Adjustable Front Track Bar
- HD Adjustable X-Flex Control Arms
- Sway Bar Disconnect Kit w/Links
- Brackets & Mounting Hardware
$949.95
