Eric,
I hope I'm not giving the impression that I am complaining but rather I was trying to point out that the park is quite diversified. I like to make this comparison since R&V is an offshoot of Snowsnake: To be a well rounded attraction, a park needs to have from the mild to wild. A ski resort needs a mix of green bunny hills all the way to a double black diamond. Same with Cedar point. There is something for everyone. That's the way it should be.
I also like the numbering system. Here is something I put together for GLFWDA 5 or 6 years ago. It's been changed a little bit since then but it give a person the ability to make a judgement on how their vehicle fits into the recommended requirements. It can be found here.
http://www.glfwda.org/index.php?page=trail-ratings
It used to be a downloadable document but somebody changed it. Here is the text:
Each trail has a rating of 1 to 5. Although subjective - what is a level 4 to a novice off-roader can be like a simple jaunt for a veteran - the scale is a pretty good indicator of the driving skill level and equipment needed in order to enjoy yourself on the trail. Level 1 trails are considered to be the easiest, while level 5 trails are the hardest and require experienced drivers and well equipped vehicles.
One (1)
Stock Run. This level is for the novice off-roader. 4 Wheel drive will be needed occasionally for a few "tough" spots. Bring a camera and the family. At this level everyone can relax and enjoy the ride.
Two (2)
Stock Run. For the little more experienced 'wheeler. 4 wheel drive will be needed a lot. Stock vehicles with stock tires are OK. Stock tires will be at their limit. Still an enjoyable ride, and a great way to climb into the 4x4 sport! Small hill climbs, shallow mud, loose sand and shallow water crossings should be expected.
Three (3)
Moderate Run. Action-packed and challenging, for moderately experienced 'wheelers. 32"+ aggressive treads are needed, rear locking differentials are helpful. Rocky steep terrain with deeper mud and water. Driver should expect to get stuck and require some spotting.
Four (4)
Advanced Run. High-intensity, adrenaline-pumping fun! For experienced wheelers only! 32"+ tires. One locker is a must. Dual lockers are recommended. A winch and tree strap is recommended. These trails require a co-driver / spotter and heavy concentration. Large rocks, deep mud with rocks and steep hills. Team efforts are required.
Five (5)
Extreme Run. This is the real deal for experienced off-roaders! Front and rear lockers are required. You must have a winch and tree straps, 35" or taller tires, and little regard for your rig's body panels. You can expect cosmetic and mechanical damage on some of these trails. These trails require a co-driver / spotter and your undivided attention. Bring a camera and expect to get dirty!
I had pilferred it from the Superlift Park in Hot Springs and then modified it. This is their original;
Trail Ratings
Level One
This level is for the novice off-roader. Four-wheel dive will be needed occasionally for a few "tough" spots. Bring a camera and the family. At this level everyone can relax and enjoy the ride. Level Two
For the little more experienced 'wheeler. Four-wheel drive will be needed a lot. Stock vehicles with stock tires are OK. Still an enjoyable ride, and a great way to climb into the 4x4 sport! Level Three
Action-packed and challenging, for moderately experienced 'wheelers. At least 32" aggressive treads are needed, rear locking differentials are recommended. Level 3 requires more concentration than levels 1 and 2. Level Four
High-intensity, adrenaline-pumping fun! For experienced wheelers only! At least 33" tires and front/rear lockers are a must. A winch and tree strap is recommended. These trails require a co-driver / spotter and heavy concentration. Level Five
This is the real deal for experienced off-roaders! Nobody gets on a Level 5 trail without being locked front and rear. Your must have a winch and tree straps, 36" or taller rubber, and little regard for your rig's body panels. You can expect cosmetic and mechanical damage on some of these trails. These trails require a co-driver / spotter and your undivided attention. Bring a camera and a clean change of underwear.
Hope this clarifies,
Jim
