1 - 20 of 21 Posts
well i got 3 out of 4 out witha press. I can not get the lower passenger side out. I bent nate4d's press trying to get it out but no luck :tonka: . I do not have a set of torch's but may be able to borrow a mapp gas setup i think. any idea on how to get this mofo out.
this is on a 2000 TJ with a dana30 c'd axle.
Happy,happy,joy,joy
hot hot
You guys are not talking about heating up a control arm or axle housing are you?
You can get them out dry - like removing a rusty bolt (tighten and loosen a bolt). In this case press the ball joint in and out - clean up the sides with sandpaper to make things easier. Use a penetrating oil.
Too much heat on anyting will weaken the metal.
Stick it up your ass
I can give ya a hand in a little while if you want.
The Green Machine
How did you get 3 of them out without a press? I have replaced my ball joints 6 times in the last 3 years and have always needed to use a press.
Living on the Edge
just to let others know that read this thread. harbor frieght sells a 4x4 ball joint replacing kit for relatively cheap. I've been using it for yrs without a problem replacing my ball joints.
good luck.
1 - 20 of 21 Posts
