1 - 2 of 2 Posts
PARTS SLINGER
LOOKING FOR SOMEONE LOCAL(80 mile radius)THAT CAN RECENTER MY H1'S OR AT LEAST CUT OUT THE CENTERS AND I'LL WELD IN THE NEW CENTERS. IS THERE ANYBODY LOCAL THAT SELLS NEW CENTERS?
I can cut the centers out for you. I already have the files for a couple of different designs or I could make your own design if you would like. You should also look into some outer reenforcment rings for the outer lip because those bend easily. I happen to have those too. Cutting out your stock centers is pretty easy and could be done with just a torch and some grinder cleanup. See my hummer wheel build thread in the fab section (or general tech I forget) and see the ones I made already. PM me for details on that if you would like. Plus I travel through Marlette once a month for work too so I could pretty much deliver them or meet you somewhere close. Later, Tab
1 - 2 of 2 Posts
