201 - 220 of 227 Posts
Discussion Starter #201
4 wheel power disc swap (currently 4 wheel manual drum)
Lower it 1.5-2" with aftermarket control arms
New wheels and tires
Possible leaf to 4 link conversion
Then drive it for the summer. 327 4spd.
Next winter LS swap and 4l80e
Axle breakin' 101
I would leave the drive train intact if its an original 327 car. Those are great engines, keep it original. Too much LS in everything in my opinion, nice car. Suspension and brakes definitely.
Discussion Starter #204
It's not the original trans or engine. If it was more then a base model car I might leave it alone. But, it's just the entry level model.
Yooper In Training
I probably won't turbo. I don't want to cut up sheet metal to make room for the intercooler etc.
Just quoting this so in 6 months when the car is tubed out with twins and a giant intercooler we can look back on this silly comment. Go ahead and order the mini tubs for the rear, I bet they won't even get surface rust before you install them.:teehee:
Discussion Starter #209
It's been 13 days since I brought it home (purchased) .... But I've....
Swapped the 4 wheel drum Manaul brakes for 4 wheel power disc brakes. W/new booster, valve, and master.
Complete new brake lines and hoses. Swapped all the 7/16 lug studs for longer 1/2 studs.
Swapped the 4 control arms for aftermarket arms w/ proforged ball joints. Lower coil buckets drop ride height 2"s retaining stock height coils.
New moog coil springs and bilstien shocks.
Swapped the sway bar for a Hotchkiss 1.5" bar.
New Hotchkiss rear 1.5" drop leafs with new shackles and bushings.
New mufflers 😂. And rebuilt/sealed the manifold to pipe connections.
Plugs, fuel filter and hoses, and fuel pump. Air cleaner.
Wheels and tires
Moser diff cover and fluid change.
New pedal pads lol.
Rear package tray replaced.
Rear bilstien shocks are on the way.
Can't wait to put some miles (and smiles) on it. Won't be as "fun" as my marauder to drive. But I bet I'll enjoy it more.
Gustafson
:rock: Very Nice! I look forward to seeing the "build" on this one. :teehee:
Discussion Starter #212
Been working on the interior now..
2014 camaro sears and console. Relocated the parking brake to the console and picked up a new tilt steering column.
Discussion Starter #214
Yeah. It took a bit of work. I refused to modify the floor pans to better fit the seats. So it's about perfect for me. But if your taller then me, probably not gonna be comfortable to drive lol.
I only wheel a boat.
love that interior!
Got rocks?
Ok help me understand this. Here is how I see your transition:
FORD Ford ford Ford/Jeep ford/jeep ford/jeep/chevy ford/jeep/CHEVY and here we are today.
Is this kinda like a Bruce to Caitlyn type transition, or are you just unsure of your identity?
:teehee:
All joking aside, as always, love to follow your builds. :)
throttle jockey
Nice car. You are probably not but I have a 327/powerglide out of a 1st gen camaro if you’re interested in it before I scrap it. Trying to really clean out some stuff after my move to the new shop
