181 - 200 of 227 Posts
Discussion Starter #183
:sonicjay: we learned a bit since that photo about e85 afr and ignition timing. It's even crazier now. Hoping to get to the track soon. Lots of those marks within a few radius of my house trying to dial it in :sonicjay:
Discussion Starter #184
Took the car out to Gladwin Michigan for "thunder on the strip". They shut down the airport and run a 1/8 on the taxi runway. It was pretty cool, felt very nostalgic.
I met up with a guy from a local Facebook group for some races. He had a p71 that was pretty well gutted, 150 shot, drag slicks, 4.56s etc hes setup to run 1/8 pretty well. He took me to school at every light lol. I was trying to work on my 60' which I suffer at. Unfortunately they weren't tracking that on the time slips. But the first race I only launched at 1 psi, then the 2nd and 3rd around 4-6 and spun each time.
https://youtu.be/c2bs-zW6q-g
Discussion Starter #187
Well I got my goal, went to the track last night. Launched at 11psi and cut a 1.56 60' , seemed to hold and not spin. Hitt a peak of 18psi on the pull. But I was banging on the rev limiter top of 3rd at the end of the track. Track officials made a trip by me in the pits and gave me a warning for being to fast w/o a cage.
2019-10-04_11-18-27 by Cheapthrillb2, on Flickr
So I made some adjustments in the tune, raised the rpm shift point of the 2-3, and raised the rev limiter a couple hundred to drive and keep it off the rev limiter. Also bumped peak boost to 20-21psi. Unfortunately, my next pass the track didn't hold the launch and I spun. Got out of it, got back into it to the 1/8th then coasted to the 1/4, still ran a 14 sec lol. Then my fourth and final pass, I launched at 11 psi again and my yukon duragrip blew apart :(. Specifically the two smaller spiders gears broken in half.
2019-10-05_01-29-35 by Cheapthrillb2, on Flickr
Shock loaded the drive train, so I'm gonna pull the trans as well and have it gone through for inspection. Car has 4.10s in it, they appear to have survived, but I have a set of 3.55's on the shelf I've been meaning to put in. Guess now is a good time. But I need to decide what direction to go for a new carrier.
Discussion Starter #190
Big thanks to @nd4spd71. He drive my truck to the track with my stuff in it, and helped go back to get the trailer, load it and everything. Fun night even with the carnage.
Discussion Starter #195 (Edited)
Update, I purchased FRP 3.55's to replace the 4.10s. And A tru-trac to replace the duragrip. I've nothing but trouble trying to get the gears installed and set up correctly. Was doing it at home on jackstands, and with my wrecked back it was hell. I need to get the car out of the garage one way or another. So I just tossed them in sloppy after several hrs of messing around with them, to get it to move. That was a two weeks or so ago.
Yesterday I trailed it to a buddies who has a hoist to reset the gears, still, after hrs cannot get a good pattern. Ended up calling it a day yesterday after my back started to flare up. Can only take that carrier in and out so many times. I've set up way more then my share over the years, idk whats going on with this setup. The FRP 4.10s damn near dropped in perfect first try.
I also pulled the 4l80 out and had it gone through to make sure there was no collateral damage from the locker failure (shock load), we found nothing damaged. That was a relief.
2019-12-24_10-43-03 by Cheapthrillb2, on Flickr
2019-12-25_10-00-36 by Cheapthrillb2, on Flickr
Don't have a lot of winter plans for the car, probably change up the exhaust again. Run it out the back to mimic stock, and replace the boost valve with a electric cutout instead. Most my attention will be out towards the jeep this winter.
I did pick up a new daily driver/commuter car ( I hate driving my truck in the salt). Drove from Grand Rapids MI to Cincinnati OH and bout a 2004 Town Car ultimate with 70K on it. Was looking for a dark blue ext and black interior but those are apparently like unicorns. Spent two months looking and only found two and both weren't in the best of shape. Settled for a silver birch ext and black interior
20191215_201315 by Cheapthrillb2, on Flickr
Needed an old man car for my old man back
Discussion Starter #196
Gears and locker all done and car back in storage. Apparently I had a issue with the bearing and race for the lower pinion positions. I was mixing two brands that don't play together.
Rinse b4 slumber
20191228_185610 by Cheapthrillb2, on Flickr
20191228_185623 by Cheapthrillb2, on Flickr
20191228_195313 by Cheapthrillb2, on Flickr
Making a tune adjustment before test drive, as last time out was at the track and had the "kill tune" in it lol.
received_2538811643025563 by Cheapthrillb2, on Flickr
Ready for that test drive..
20191227_222329 by Cheapthrillb2, on Flickr
Discussion Starter #198
Well this project will come to an end later this year... Purchased its replacement this past weekend.
Mr brother bought it mid to late 90s, then my step dad took ownership 2001. And now myself.
