1 - 17 of 17 Posts
In Da Faaaaaace!!!
1988 YJ
The other nite I shot some rustoleum primer through the spray gun. It is all dry now and it seems to scratch fairly easy. Just wanted to see if this was normal or not?
In Da Faaaaaace!!!
1988 YJ
Discussion Starter · #4 ·
ok so it is supost to come off when i take my nail to it? I used it because i had it laying around and wanted to see how it worked. I might scrap the idea, but i wanted to do a cheap paint job.
One arm steve - I'm going to the paint store later today. I'll see what they have to offer.
In Da Faaaaaace!!!
1988 YJ
Discussion Starter · #7 ·
allrite good. I also know that primer is not seal proof :thumb:
Since i have never painted befor ... with a gun
How many layers of primer should i lay? 5-7? Than how oftens hould i wetsand...after every 2?
Also do you know if you can spray an acrylic paint over enamal primer?
Playing Possum
It doesn't matter how many coats you put on it as long as you can wet sand it before real paint and not hit metal. A couple coats is usually enough because it goes on thicker. You can paint acrylic over enamel.
In Da Faaaaaace!!!
1988 YJ
Discussion Starter · #11 ·
I wan't to do this paint job on my entire jeep for cheap. I do not want to spend $300. I'm gonna goto the paint store later tonite and talk with the guys on the PPG stuff. I'll let ya know what i find out.
thanks guys!
In Da Faaaaaace!!!
1988 YJ
Discussion Starter · #14 ·
Hmmm well i just wet sanded it all with 600 grit and it seems like it stays on good. I'm down to bare metal in some spots so i'm gonna shoot mabey 4 more layers than wet sand again. I have time :)
I just don't wan't a nice paint job costing over $300 as its going to get scratched. Also when it does, i can just touch it up much easier with spray bomb.
Simplify...
Rustoleum in general scratches very easily, and it's oil-based, so you can't top coat it with Krylon (you'd need to stick with Rustoleum or similar topcoat). Why risk putting all this time into something using old, crappy primer? :poke:
Craig
1 - 17 of 17 Posts
