1 - 12 of 12 Posts
Premium Member
Has anyone ever repaired a poly kayak? Ours has developed a small pinhole in the stern where the boat has (stupidly) been dragged over concrete over the years.
I found repair material, but don't have the "welder" which you can buy for $70. Any alternatives so I don't have to buy that thing?
I would clean the inside over and over and over and just use a 2 part epoxy. Issue is the epoxy won't flex well, but hopefully it is in the steep "V" portion that doesn't flex much.
Premium Member
Discussion Starter · #6 ·
It is in the steep portion, I've read that it's really hard to get anything (including epoxy) to stick to them though.
Thanks, found that too. I read closer and see that they do have a "heat a drill bit" method if you don't want to buy the welder. Some other people heat a spoon with a lighter heroin style. I think adding more plastic is the best way to fix it, and I can build that abrasion back up.
WHISKEY-TANGO-FOXTROT
heat gun and putty knife
I had the same issue with one I picked up for my son last year. Chances are if you have a pinhole the rest is worn thin and needs built up. I would check with some local kayak rental places and see if the can do it for you. That is what I did and it was cheaper and he built the keel area up that was thin. Most rental places in my area do this repair on a regular basis. If you do do this repair yourself 5 gallon buckets use the same type of plastic and are a good source of plastic.
cool idea. You could also practice on the bucket before you burn a huge hole in your kayak lol
Premium Member
Discussion Starter · #11 ·
Good idea on the livery, thanks. Yeah, I was planning to build it back up if I did it myself. You are right, a lot of it is worn down. Thanks!
1 - 12 of 12 Posts
