1 - 20 of 20 Posts
SOLD!
For Sale - Poison Spider Chassis - 6.0L Buggy
Location: Grand Forks, North Dakota – Contact Lon 701-741-0513
Price: $23,000 (will consider two seat moon buggy trade or small rock crawler, will also consider trades of TJ, LJ, JK, JKU, Polaris RZR XP 1000)
New price option.
$20,000 without tires and rims - you supply your own
  1. 110” wheelbase Poison Spider Chassis
  2. Chevrolet 6.0 V8, engine cammed to approximately 400HP, ecm and harness by Schwanke, Kevko oil pan with baffles, K&N air filter, remote mounted oil filter, Dual exhaust with mufflers
  3. TH350 TCI transmission with reverse manual valve body, with 10” 2500 stall converter and Art Carr shifter, Derale transmission cooler with fan
  4. Front axle – GM D60, 5.13 gear ratio, Detroit locker, full 35 spline chromoly axles with Yukon Super Joints, full 4 link suspension with all 1.25” heims, Blue Torch Fab truss, diff cover and pinion guard, PSC full hydraulic steering with double end ram, 8” Derale fan driven cooler and full disc brakes
  5. Rear axle – GM full float Corp 14 bolt, 5.13 gear ratio, with Detroit locker, full 4 link suspension with all 1.25” heims, Blue Torch Fab truss, diff cover and pinion guard and full disc brakes, rear Currie Anti-rock sway bar
  6. CBR double pass rear mounted radiator, 27”x19”, with two fully shrouded 12” fans, rear mount with braided lines and AN fittings
  7. 14 x 2.0 King Coilovers front and rear
  8. Atlas 5.0 transfercase with Atlas cable control linkage
  9. Interco Super Swamper TSL/SX 43x14.5x17 SXII tires on 17” Raceline
  10. aluminum beadlocks
  11. Warn 9.5TI Winch, 100” synthetic rope, hand remote and cab mounted control
  12. Moroso Performance Rocker Switch Panel with breakers, Portable air compressor and fire extinguisher installed in cab, Quick release steering wheel, Autometer Gauges - Tachometer, Oil pressure, Water temperature, Transmission temperature, Voltage, 16 Gallon fuel cell, Corvette style brake master cylinder with booster, all steel braided brake lines with AN fittings, high back 5 point black vinyl bucket seats and 4 point seat harnesses
More images at the following link:
https://goo.gl/photos/pQYx75UUxe8KFeJk9
FORMER BULLET CATCHER
Sexy
1 - 20 of 20 Posts
