1 - 4 of 4 Posts
Same motor that I posted in the feeler thread
AFR 195 heads 64cc with the steam holes drilled,with PRW 1.5 roller rockers and Edelbrock signature series black ALUM value covers $1300
Taylor .409-inch, 10.4mm diameter high performance ignition wires $75
Comp Cams Retro fit roller lifters $375
Eagle 13008B Crank & rods with KB HYP -30 dish pistons $700
DOUG THORLEY Tri Y Ceramic HEADERS $300
Full dual 2.5 exhaust with flowmaster 70 series mufflers no cats $400
That's the main stuff I would like to sell first. if someone buy the crank all the little stuff will then be for sale IE coyles Quite gear drive, 7 QT Moroso Oil Pan and the block.
your mom likes me best
this would work great in my short box. what`s the est.horsepower & are you looking for any kinda a trades ??
Discussion Starter · #3 · (Edited)
dynoed out at 422hp & 438lbs tqu with bad fuel map
recap on the motor
SBC 408
Had edelbrock Pro Flo 2 EFI but sold it to S10mudder here on the form.
AFR 195 64cc heads with drilled steam holes
PRW Roller Rocker 1.5
Comp Cams XR270HR 218/[email protected] .492/.502 lift HYD ROLLER
Comp cams retro fit Hyd Roller Lifters
eagle rods & crank w/ KB +30 dished Hyp pistons
Meling High Flow Low pressure Oil Pump
moroso 7 Qrt oil pan
Coyles quite gear drive
Edelbrock water pump
Powermaster Starter
Powermaster 140amp Alt
ARP Head / Main & Rod Studs
Stage 8 header bolts
Always open to reasonable trade's? Selling complete for 3,000
1 - 4 of 4 Posts
