81 - 100 of 1,234 Posts
nope, atleast not intentionally, with this truck will come a new style of wheeling...........Explorer was balls to the walls, drive it like you stole it, no regard for damage and carnage............
This B2 will be more skill involved and patience etc...style of driving
:confused: come on john, thats what made it fun wheeling with you. never quite knew if you were going to make it home:tonka:
Discussion starter · #83 ·
and it will be wheled all out, but before it was all out right out of the gate, now it will be finesse till it needs to be all out
Discussion starter · #84 ·
well took the rear axle out and cut the perches off, had to reangle the pinion, also redid the frt axle mounts for the coils and put the y-pipe and cats on
I've seen you drive your Exploder, you have that young, no fear thing going on. I have a hard time seeing you slow down to much, especially with a capable rig.
I found the bigger I made mine, the more trouble that I got into.:tonka:
Discussion starter · #86 · (Edited)
best pic i can get right now, been working on alot of things that aren't picture worthy (wiring, etc...)
got the 8" springs in it, got my pinion angle set on rear, and got everything for the rear susp set except shocks, got the engine install done and everything hooked up and full of fluids, working on wiring up the brake lights and interior lights
The old explorer looks pretty sad doesn't, far off from its heyday
Discussion starter · #88 ·
cats?
heres a shot of the coil mount i made on the left
its is 4x4 sqaure tube notched like a spring perch and welded to the tube, then theirs a really thick washer about 6" round welded to the 4x4 and the stock D35 TTB bolt holding the nut and washer that holds the coil down
dibs on the lights:sonicjay:
Discussion starter · #93 ·
i've read to many articles and talked with to many ford RBV guys, no cats/gutted cats hurt performance on 4.0L engines, i have one stock cat on my truck
Looking very good! You are moving at warp speed compared to others on this site :tonka: :tonka:
Discussion starter · #98 ·
rewired the rear lights tonite, that was horrible
Bronco 2 runs the harness along the frame rail, Explorers run them through the interior...........since i swapped in the explorer dash and wire harness i took apart the loom and found the wires needed for the lights ran those along the inside of the body and out to the tailights and got them all working nice and good, took a while, its nice having the manuals on hand
Discussion starter · #99 ·
things i am in need of to finish
1. 4.88R D44 Gears
2. 1989-90 Bronco 2 gas tank, straps, fuelpump sender (86-88 tanks work to, but 89-90 prefered)
3. lug adapter s 5x4.5 to 5x5.5
4. F150 D44 axleshafts (my axle is a 77)
