1,041 - 1,060 of 1,234 Posts
Discussion starter · #1,044 ·
Front carrier is installed and the shafts are in the front and the bearings are repacked, but i forgot the sockets to tighten the jam nuts so i couldn't finish that up. And i bought a 1310/1350 conversion joint but turns out i need a 1330/1350 so couldn't wrap up the rear driveshaft. But i did get the rear drums off and the brakes look good other then one wheel cyl and a drum resurface so that should be mostly wrapped up tomorrow. Hoping to get it pulled out of the garage as i have some side work on some other trucks that need to be done this week.
That thing gonna fit on your trailer now? Looks a little wide:sonicjay:
looks good john...now go beat it and not think twice.
Looks like if you had wider axles that wouldnt happen.:sonicjay:
