861 - 880 of 1,234 Posts
body needs more purple, dash needs to be green and i can call it barney!
are you going to throw full front clip on it? or some kind of tube contraption?
Discussion starter · #865 ·
Got the front clip assmebled.....
Also got the 38's on it, and relocated my rear axle and susp to gain the clearance on the cab.
A stock B2 (its a B2 Frame) has a wheelbase of 94" I have stretched the wheelbase on my frame to 114"
Discussion starter · #868 ·
Picked up a saginaw power steering pump....modifiy my stock bracket to accept it, no more whineing and pump fade from the junk stock RBV pumps.
Thats a swap I would like to know more about!
Discussion starter · #872 ·
Heres the stock style hub i run (this hub has now been through two chrome moly's) that is still good. And below it is my Yukon Chrome Moly that i broke at rocks/valleys two weeks ago.
I purchased them from Broncograveyard early last year. Shattered the LF inner/outer last summer. Blew all the ears off the inner and the stub. The 5-760x ujoint held though. So it wasn't a ujoint failure. So i got that one warrantied. But now i broke this one. But because i got the Left side warrantied already for free, now i cannot warranty this one because its only warrantieable one time. So I'm now SOL with the stub and would have to buy a new one at full price to replace it.
I think i may send yukon an email. I think its BS that i have eaten 2 chrome moly's on a stock warn style hub and the hub has held each time.
Discussion starter · #874 ·
This break was with my 38's, last years break was on 36's
I could understand if i was running a stout V8 and the wieght of a fullsize truck. Or hell even a welded front axle.
Its just a dman explorer with a 4.0L and an aussie locker. Hell when this stub broke it didn't even take out the pins in the aussie.
john did you call yukon? i had 2 of the same side warrantied.you need to call them and complain..they will most likely take care of it.
i didnt say a word.....:sonicjay::sonicjay:
the bad part is..... when you broke this one, you werent even beating on it hard. a little hop, but not bad. ive put my stock shafts through more than that??
