541 - 560 of 1,234 Posts
Discussion starter · #543 ·
yes, what you can't see in the vid is the large rock and the stump sticking out of the top of the hill facing the tire of the truck. The rock and stump and right in the middle so you have to dive left or right at the top
Discussion starter · #547 ·
I did find some new damage from the trip though...my trans crossmember was broken in half......i thought i broke the mount, but dropping the tcase today found i was wrong. Broke in half right next to the mount.
Discussion starter · #552 ·
My guess would be that the plasma cutter is going to be getting a good work out along with the tube bender.
i may have gotten a little carried away with the plasma yesterday :miff: I bought new bits and peices for the plasma ($100 in parts) and it works so nice now. I might have to work on damage control from my trigger happy finger yesterday.
I need to lower it cause the COG was to high. Their was a few obstacles i did not try at the Badlands last week, because of the tippy feeling. SO i removed the 3" Body Lift which means AGAIN i need to modifiy the cage. But also means i need to do some serious trimming to the body so the 36s can flex. They barely cleared the body when i had the 3" BL on so now i have lots to do.
Discussion starter · #553 ·
Replaced the Tcase chain today. It was stretched and their was evidence of it slaping the case. I just pulled the cahin from a low mileage E-tcase. A new chain was $90 and i just don't have it right now. I am sure the used chain will do fine. It wasn't nearly as involved of a process as i thought it would be to change.
