181 - 200 of 1,234 Posts
Discussion starter · #182 ·
so i busted my LF shaft right at the splines were it goes into the carrier,
perfect break, makes no noise when turning and leaks no fluid
i thought the hub broke until i pulled the diff cover and spun the driveshaft and the ujoint didn't spin
so the tally is now 2 busted shafts, bent tie rod, and two RF ball joints from the pig gig
Discussion starter · #184 ·
yep , sunday i'm driving to Detriot to get two more shafts and two sets of steering linkages and a trac bar so i can do it all over again lol
Discussion starter · #187 ·
the little stub spline came right out with a magnet. So i got the frt axle back together. Fixed an elec prob i had. I also figured out how to get it onto the trailer that i have here. Unfort it involves stock rims and 235/75 tires to clear the side rails. But i am still in need of two more Stock f150 rims for the rear axle to get it on the trailer
Discussion starter · #193 · (Edited)
i got it put back together with the new/used parts. I layed a bead of weld down in the neck down area. Just enough to fill it but not touch the seal as it slid through. I'm curious to see if it'll change anything or make the shafts weaker. I am taking it tomorrow for another round of abuse. Have to see how it holds up.
I took the doors off it today and I LOVE how much more vision it gives me while wheeling. I can see everything. And my doors are light enough to where i can unbolt and bolt them up on my own. I then took my old mirrors and attached them to the fender so i can still use them.
Discussion starter · #194 ·
well i busted both my shafts again, both at the neck down. I also bent the tie rods pretty bad.
Its parked in Hart right now (thanks fullsize4life) we left it up north cause we needed to bring a buddies back on my trailer
But when i get it home, its parked till i build/buy a roll cage for it. I am done playng without being protected
Discussion starter · #196 ·
john before you spend the money let me call coop and see what he would charge and if he has time..will be nicer and cheaper i am sure.he is in twin lake.
Discussion starter · #200 ·
Well i just got it home from Hart, Fullsize4life was babysitting it for me for a week or so lol
Long boring drive by yourself
i got an Pass Side shaft so thats gonna get put in within the next few days but i am still insearch of a Drivers side shaft to replace my broken one. I really only need the inner peice the stub shaft is fine.
