Received a router for Christmas from my parents. Some quick metal fabrication and its now CNC controlled! Never knew how fun wood could be... plus it does not throw off god awful fumes into the air and is easy cleanup with a vacuum!
First cut...not so great. Great progress overall since it actually worked. The issue is the float Z-head that is used for the plasma cutter. Also used a normal router bit. SheetCam generated toolpaths...EEK!
Used a 4 flut endmill I had for the Mill. Also locked the float z-head with a bolt. MUCH BETTER! Looking at different bits, they make specific router stuff for this....Looks like I need a down cut bit. The mount still needs to be fully welded so some of the play/vibration is being transmitted into the workspace.
5/8" pine, .125" per pass at around 40ish in/min with a 1/4" bit. Using Fusion 360 to create the toolpaths now...MONEY!
