1 - 8 of 8 Posts
So I decided to start the Jeep....Turned the key and it just kept on cranking...even when I removed the key..had to disconnect the battery to get it to stop.
Is this a bad starter or something in the ignition wiring?
Buy a Fiat! Save the UAW!
sounds like starter relay stuck on.
Inside of the passenger fender. You'll see cables running from it down to the starter. I used to have things like that happen in college and would just punch the underside of the fender to get it unstuck. Its a cheap part. Replace it.
so violent have you always been this way?:nana: :bdr2:
1 - 8 of 8 Posts
