1 - 5 of 5 Posts
Sore and Tired 24/7
I am buying a universa fuel pump for an 82 cj7 4.2, i need to know should i run the 2-4 psi one or 4-6 psi one.
HURL SCOUTS
iirc the stock carb requires only 3 lb? maybe someone can back me up on that.
Premium Member
Are you running the stock Carter Carb? Are you buying a replacement mechanical? I think my factory replacement mechanical put out like 11-13, cause when I went to a Weber I was told I had to have a regulator on it down to 4 or something like that.
Sore and Tired 24/7
Discussion Starter · #5 ·
I got it, and have to return it now, battery just wasn't turning the motor fast enough. Guess i just needed a new battery, happy i didn't install the electric pump.
1 - 5 of 5 Posts
