1 - 6 of 6 Posts
· Get Some
I have a 79 mercruiser out drive, and when you put the boat in reverse the out drive lifts up out of the water. As soon as you take it out of reverse it drops back down. Any ideas?
· Merkin salesman
Bust Out Another Thousand. With the boat out of the water, put the outdrive all the way down then grab onto the bottom of the it and try to pull it up. It should not move at all. If it does, your trim cylinders or valves are shot
· Get Some
Discussion Starter · #6 ·
i can lift it pretty easy, There is a valve attatched to the shift linkage that I was told could be the problem, I have not had time to check into it though.
1 - 6 of 6 Posts
