41 - 60 of 105 Posts
· Whoop Whoop
Discussion Starter · #50 ·
1946 cj2a dubbed mary jane
3.7l mercruiser with a t5
Cj5 dana 44 rear
Dana 35 converted into a beam from axle (removed pig)
Coilovers in front
Airbags in rear
305/65r17 in back and 30x9.5 in front
Also going to be making some beadlocks for the sprint car tires to swap onto the rear for dooones
Assuming i like everything, plan to hop up the merc in the future and shave weight on the engine. Aluminum bbf head shaves around 30#.
Figure i can drop about 20 off the rotating mass.
The secondary vibration from the pistons have me a bit worried to push too much power.
Just wrapped up the rear axle last night. Going to start putting the drivetrain together and prepping the front axle
· Gustafson
Change is not always bad but it is always hard for the older folks. :teehee:
RBB:usa:
:( I'm only 36.
Cj5 dana 44 rear
Coilovers in front
Airbags in rear
That's a really cool build!! I like that you are using the 3.7L. That's a really unique engine. (Ford 460 head, pistons, and connecting rods)
· Whoop Whoop
Discussion Starter · #53 ·
I like it. Pics of tub?
post #33 is only one I have at the moment. Had it mocked up on the stock rims/tires sitting on jackstands before putting it in the weeds for a while. gonna have to make a new floor. Too bad to be saved, so it will be reborn as a fun little hot rod.
Mary Jane comes from that vista green paint with just the right patina.
· Whoop Whoop
Discussion Starter · #60 ·
Finished up one 15x10 beadlock, welded up the second to be ground down.
Gonna put a set of sprint car tires on these for doonage. Just a pair for the rear.
Pulled the engine into the shop
Swapped the starters out. Shaved 12#ish
Broke my harmonic balancer puller. Gotta get another.
