201 - 220 of 227 Posts
· American
Unfortunately a few more clues are leading me to believe someone broke into my barn and took them...
I'm still going to hold out hope that I lost them and they will turn up somewhere but it's not looking good
What’s missing?
On a side note, if you’re looking for security systems I recommend amazon deals on Black Friday. I bought my Annke 8 camera system and 1TB SSD for $200 last year. I love it for the price.
· Registered
Discussion Starter · #202 ·
What’s missing?
Rocker arms, trunion kit, push rods, ARP head bolts, flywheel adapter, flywheel bolts, np208 32 spline input shaft, timing chain and a few other small pieces
· American
Holy shit that’s quite the list, that sucks. Idk if you have a guy you order your stuff from or not but I used Lance Draeger over on the east side for all my LS engine components. From my holley to the BTR components and even parts for my truck, I’ve bought quite a bit through him.
What do you mean by flywheel adapter? The snout adapter for a torque converter?
· Registered
Discussion Starter · #204 ·
· American
Ah. I lucked out and had a long crank 6.0 so I could just bolt everything together without having to worry about a spacer. My 5.3 though I bought a cheap adapter for the torque converter snout on amazon prime last week.
· Registered
Discussion Starter · #206 ·
Took advantage of summit racing's cyber Monday sale and ordered there LS roller rockers. They are a full roller, billet aluminum, and made in the USA! I also ordered a new crank spacer and crank bolts so I could get the 4l80e bolted to the motor. Once I got them bolted together, I dropped them both back in the truck.
Next up is getting a transmission crossmember figured out.
· F-U-CANCER!!!
I probably should have ordered a cam, springs and rockers for my ls during the sale weeks.... Think I am gonna wait another year though. Not enough time to get everything I want done it seems...
· Registered
Discussion Starter · #208 ·
I know the feeling of not enough time haha. This summer was all about boat and house projects. Now that those are all wrapped up I was planning on spending a bunch of time on this. Then I got asked to put coilovers and bump stops on a YJ and 3 link it. Now that's where most of my free time goes
· Registered
Discussion Starter · #209 ·
Trans mount pieces are all here...just need to find the time to put it all together...maybe this weekend.
I also got some more frame plates. The stock truck frame is all C channel. When I'm done with it 95% of the frame will be boxed in with just a few openings for wiring/plumbing things.
· Gustafson
Awesome! That should make it nice and stiff. Looking forward to seeing more progress on this thing!
· Registered
Discussion Starter · #211 ·
Moved this from the back corner of the shop to the front and right next to the wood stove with hopes of getting some good progress over the winter.
In the last couple weeks I got most of the parts I had on hand installed/mocked up and then started a list of stuff I need yet. As it sits right now the 5.3/4l80e/np208 is bolted together and mounted in the truck, minus a Trans crossmember which I'll need to re-engineer from my original plan. The truck is also sitting on its own weight with the 3 link and coilovers all tacked together.
Priority number 1 is to get the motor fired up. I think I built this motor 4 or 5 years ago and have yet to here it make any noise....
I need to get a steam port kit figured out, fuel system, cooling system, and wire it up. I have a radiator, cut down harness, and flashed computer already. Thinking about stealing the fuel system from my TJ for now.
Sent from my SM-G991U using Tapatalk
· In Da Faaaaaace!!!
1988 YJ
love it! What do you need to figure out with the steam ports.... run the back to the front and to the rad? Or just plug the back and do a crossover in the front? I did the plugging and crossover in the front and have yet to see any issues. I know its a hot topic with a lot of debates.
· Registered
Discussion Starter · #213 ·
I don't have any parts for steam ports yet, so I gotta figure out how I want to do it and buy parts. I definitely will run them back to the radiator. I'm undecided on venting or just plugging the back ports. Most likely will just block them off, and vent the front ones to the radiator.
· Registered
Discussion Starter · #217 ·
