1 - 4 of 4 Posts
I have two LS engines I've accumulated through being greedy and taking random things at the junkyard.
I'm in Ionia Mi, 48846.
1 is an 02 LM7 from a 02 Silverado that was wrecked. Has accesories, no harness or PCM, ran in the junkyard, 400 bucks.
The other is a 6.0 LQ4, it's an early, long crank, iron head LQ4. The iron heads flow identically to the 317 alloy heads if you didn't know, I have a set of 317s you can have also if you just can't live with iron.
It came from an impound 2002 SIlverado 2500, and ran in the junkyard. It has the harness, PCM, and Fusebox. 800.00
1 - 4 of 4 Posts
