1 - 20 of 46 Posts
Geocacher!!!!!!!!!!
O.K. so, I got this used router.
Thought I hooked it up right but no internet.
Did I miss something??
cable from the P.C. to port #1 on router.
cable from my DSL modem to internet port on router.
plug them both in to wall outlet.
waited for them both to boot up.............
No internet
Geocacher!!!!!!!!!!
Discussion Starter · #3 ·
No wired internet.
havn't tried the wireless yet (daughter is on her way home from Western tonight with her laptop).
U-Joints Fear Me
try unplugging the router and the modem and let them both reset, if you haven't already done that. may want to try a different port on the router just in case its screwed up, my linksys has a bad port on it.
yeah you have to resest the modem while the router is hooked up, because the modem has a security feature to where it only allows the ip address it is connected to, to work. So just have your router connected to the modem and plugged in, then reset the modem. To reset the modem, just hold the reset button for 30 sec or if it doesnt have the reset button, just unplug it for a couple minutes
Geocacher!!!!!!!!!!
Discussion Starter · #9 ·
Unplugged both and plugged back in and pushed the reset button on back of router.
Also tried all of the ports on the router.
Geocacher!!!!!!!!!!
Discussion Starter · #10 ·
Check out page 13 of the manual. I'd also check out Chapter 6 on page 14, see if you can log into it and check out the settings.
U-Joints Fear Me
type in 192.168.1.1 into your browser and see if a password box pops up, this will at least tell u if your connected to the router.
Geocacher!!!!!!!!!!
Discussion Starter · #15 ·
Read page 45 of manual, it says if your power light is flashing, your firmware is hosed....you'll have to try and reflash it. Power light should be solid.
Be careful if you try to flash the firmware, if it's done wrong, you can really screw up the unit if it's not already been done.
Geocacher!!!!!!!!!!
Discussion Starter · #20 ·
Went throught the set up on the control panel and nothing is working.
I wonder if the unit is toast.
I did notice that when I switch the cables, the Ethernet light on the modem goes out.
Power light on the router is still blinking.
1 - 20 of 46 Posts
