61 - 80 of 86 Posts
Premium Member
Discussion Starter #61
I gotta give you credit for tackling that. I HATE wiring, HATE IT!
Lol. I’ve done a couple harnesses and actually find it pretty satisfying. It so different from the work I do everyday it fills a mental void for me. Don’t get the wrong idea, I’m no genius. There’s no way I could do this without help from the lt1swap.com website.
Hopefully that pays you back with a summer of no oddball issues that ruin your weekends at the dunes.
I hope so too... As I was working through the harness uncovering each mess it became apparent I would be screwed if it ever had an issue.
I didn't look at it. Pics are way to big for my screen.
Weird, I uploaded the same as always using Tapatalk. Maybe check it out later on another device, it’s pretty spectacular
Sent from my iPhone using Tapatalk Pro
Premium Member
Discussion Starter #63
I just ordered this transmission cooler and I’m planning to mount it against the firewall below the battery. I’m looking for experienced opinions on whether it would work better in a push or pull configuration. Thanks!
I have mine mounted against the firewall like this pulling air into the cab. Theres a big hole right behind it where the TJ heater core use to be. So far so good with a lot of bombing around the dunes.
Premium Member
Discussion Starter #66 (Edited)
Finally got some time to get back to the wiring. The original under-dash harness was in really rough shape plus it was the older version fuse panel with glass fuses so I started over with a newer one in good condition. I mapped out all of the engine control wires not needed and used them for the LS control wires (OBDll, CEL, TCC brake relay, ECM on/crank, etc.) so every wire runs through the fuse panel rather than just pulling them through holes in the firewall. It turned out really clean and can’t wait to get the dash put back in. Hoping to get the Jeep and LS harnesses ties together this weekend.
Also, I finally found a decent set of YJ half-doors too. I’m pretty stoked about having these.
Start of under-dash wiring...
Finish
Picked this up on Amazon for less than $400 with a supply of consumables. It cuts 1/4” nice and clean.
Premium Member
Discussion Starter #71
Premium Member
Discussion Starter #72
Still working on putting this thing back together and making some good progress. The LS harness redo was a success - it starts and runs! I ordered a full set of PRP seats that should be here in another 3 weeks or so and then I need to build a cage. Plenty of little things to do still in the mean time.
I was able to get the fuel gauge working in the big speedo cluster then started messing around with the temp gauge. The temp gauge acted like it would work and I started thinking it would be pretty cool to be able to use the stock gauges to keep the retro CJ look. So I ordered a temp sender, an oil sender, oil gauge and a couple metric/NPT adapters.
Well, the temp gauge/sender is working as expected but I cannot figure out the oil pressure setup.
I have been using the Morris 4x4 tech page on CJ gauges as my reference.
https://www.morris4x4center.com/jeep-knowledge-center/CJ-Gauge-Troubleshooting/#
When I hook up the gauge the needle goes to 80 psi as if the terminal post is grounded.
According to the resistance chart I should see 240-ish ohms between the sender body (ground) at 0 psi (engine off) and the terminal post but I am actually seeing 6 ohms. I tried a second sender and get same results.
I checked the temp sender from the body to the terminal post and it reads 300 ohms cold as expected.
What am I missing here?
Premium Member
Discussion Starter #73
Pics below are temperature sender vs. oil pressure sender. When compared to the charts on the Morris 4x4 page the temp sender is measuring as expected but the oil sender is not. Two different oil pressure senders are showing the same...
Premium Member
Discussion Starter #74
Man, this place is active all of a sudden!! Like a lot of others, I miss the old forums. Anyway, some updates... been spending most of my time the last couple years helping @JeepHeap and having a blast building the Taz :)
I gave up on my idea to run the stock CJ gauges. I had the fuel indicator working for a little while but it stopped and I switched to Autometer Classics for the oil and temp.
Found some nice YJ half doors, put it mostly together, bought the Genright cage/dash stantions, built a cage and added some nice PRP seats with harnesses.
The cage needs to be tied into the frame, wiring cleaned up a little and another 100-150 WHP would be nice but it’s a lot of fun and I’m enjoying driving it.
Gustafson
Wow! What a transformation! I like it!
Any plans to upgrade the motor? (noticed above you were looking for more hp)
Premium Member
Discussion Starter #77
It’s a street and dune toy so cam and converter are on the list for sure but I need to do more research to see what I want/need. That won’t happen before next winter though. I need to focus finishing my son’s Jeep and tying up the loose ends I mentioned. It has plenty of HP for the street, the HP upgrades would be for running paddles on the dunes.... even little paddles like mine are serious HP suckers!
Premium Member
Discussion Starter #78
The back of a fiberglass CJ tub leaves a lot to be desired... okay,it’s just plain ugly but not a lot can be done. I found a guy selling actual size Jeep letter decals and Amazon had the CJ7 and Jeep badges available so used them fix up the rear some. It’s not awesome but it is better. I also did the side while I was at it :)
61 - 80 of 86 Posts
