21 - 40 of 73 Posts
Premium Member
Discussion Starter #26
I had someone do that for me a few years ago before I had a beadroller. Now I can do it no problem.
That’s awesome.... I’ll hit you up in the near future so we can discuss it. Thanks!!
Sent from my iPhone using Tapatalk Pro
Premium Member
Discussion Starter #28
I got the Jeep back from Baker Engineering, what a great group of people over there. From the front desk to the the guys doing the tuning, everyone was awesome. TJ was able to get it running really smooth, and squeezed out some decent numbers. He also did a bunch of transmission scheduling and line pressure adjustments so now it shifts like it should too. Here’s the report and it was tuned for 87 octane.
235HP and 251 Torque.
Premium Member
Discussion Starter #32
I saw it sitting at acme today, looks like a nice rig!
Thanks. Alex (owner) is friend and my son works there. I was getting a little help on the brake pedal issue today.... it still needs work.
Anyway, with the sunshine and decent temps, I couldn’t wait until April to get it on the road :)
The 5.3L is strong and runs good. Baker did a fine job tuning it and I would recommend them to anyone. Lots of power for a 3000# Jeep on 33’s and it peels the tires from a stop to halfway through 2nd gear if I want to.
Plenty of little things to do to get it ready for daily use and I hope to have time in the next couple weeks.
It is a lot of fun to drive and I’m happy to be back in a V8 CJ with ‘little’ tires, it’s been a long time.
Did you get the brake pedal issue solved?
I've worked at lakeside for about 9 years now. I've got the black Jk parked out front.
Premium Member
Discussion Starter #34 (Edited)
I’ve seen that JK there a million times, I’ll try stop by sometime and say hi.
I’m still having issues with the brake pedal, It’s just too worn out in the linkage/mounting. I have two other pedal assemblies available though so I should be able to come up with something that works/feels good.
Found 3 out of 4 steering box bolts loose and the 4th bolt was missing.... on-road handling has improved 100%.
That stupid spool in the rear needs to go soon. I will be looking for a Detroit locker for the D44 or a Ford 9” to replace it.
Premium Member
Discussion Starter #35 (Edited)
Beautiful weather today so spent a little time on the new Jeep. The brake lights have been making me crazy and prohibiting me from driving it. The issue was the lights would work fine with no key on, but when the engine was running the brake lights were on constantly. Overall, the wiring is giant mess and it is compounded due to needing all the ground wires (fiberglass body). So, I started at the lights and worked my way back.... Eventually, I made it to the brake/TCC relay and found they had incorrectly added a constant 12v along with a keyed 12v on the relay. This mistake by the previous owner caused the brake light issue, an improper TCC function and the battery drain issue - bingo!!
I did a backyard alignment too. When I started it was toe-in about 3/8” and I set it toe-out about 1/8”. It drives much better now.
Pulled the soft top off and snapped a driveway pic.... the cowl hood is not my style and will need to go.
Drone from the dual Flowmasters dumping in front of the rear axle is pretty bad, so I’m going to look into having tailpipes made up. Any recommendations on the north end of GR?
Then I stumbled upon these... solutions and problems all at once, lol.
Premium Member
Discussion Starter #36
I’ve been looking for a set of used paddles off and on since I got the baby Jeep and finally found the right deal. We made an early morning trip to the east side of the state yesterday and picked these. Going up to Silver Lake on the 11th to give them a try :)
I’m looking for a set of aluminum 15x10 or 15x12 wheels 5x5.5 bolt pattern. If anyone’s something decent please let me know.
Premium Member
Discussion Starter #38 (Edited)
:rock: That's awesome!
Well, we shall see if there’s enough motor to actually use them LOL. At least we will “look cool” and if it doesn’t work we have a good excuse for motor upgrades :)
I’m not sure you call it an upgrade but it does improve the look. I pulled the enormous tach off the steering column... much better. Eventually I will redo this dash and installed a 2 5/8” tach. I found a company that makes some really cool electronic gauges that have the original look.
If anyone is looking for an Auto Meter tach let me know. I don’t know anything about it but it seems to work fine including the light.
21 - 40 of 73 Posts
