1 - 20 of 22 Posts
Anyone with a Tj running a supercharger, instead of the traditional V-8 swap?
If so any problems with it? Any help would be great.
Thanks for the help. Bill
Premium Member
We have a guy in the club who has one on his Rubicon. The only issues I believe he has had is with heat. I am not sure if he has gotten the problem worked out or not. He has all of his work done for him since he isn't mechanical.
My name isn't really Bob!
Actually Bill, I have one too :thumb: . I use an Eaton supercharger off a Supercoupe. No issues with mine. It makes 6lbs of boost just like the big name suppliers. If your interested I can sell you a kit for half of what they do.:nana:
Discussion Starter · #6 ·
Hey Guys,
thanks for the info. I e-mailed Kenne belle, you are right as of now they stopped making the kit for the 4.0L... Does anyone else run some other supercharger?? Avenger, or ???
why only 6 lbs? my eaton pushes close to 20
The N3rd
Hey Guys,
I met a couple guys at camp jeep a few years ago running the Avenger. Heard nothing but great things about it. Hopefully will be doing that to mine a few years down the road.
I got a gold chain
I wheeled with a guy down in Harlen that had one. He said he wished he never spent the money for it.
Useless for wheeling, only benifit was high speed road driving.
I guess it depends what your looking for.
Because the motor is basically stock, and isn't made to handle 20lbs of boost. I could easily make 20 lbs of boost, for a short time, then the head gasket would blow out.:miff: Its all about making reliable power.
are you running a wastegate on the eaton? Most eatons have no control over how much boost they build, other than pulleys.
I use a by-pass valve. The valve opens as the throttle closes, such as when you let off the accelerator. This allows the air to recirculate so it won't over-boost. Basically, the amount of boost is controlled by the pulleys.
1 - 20 of 22 Posts
