bought a 88 blazer with a 4 inch lift 35s with a fuel injected 350 with a sm 465 with new gears and clutch and flywheel installed.. stock 12/10 bolt with 410s and a detriot locker rear...35 baja claws radails... solid body with no rust with a few little surface rust spots.... plans are a 8 inch all spring bds lift and new 38 boggers.... will swap to a d60/14 bolt later once i get tired of break axles... ill post pics of the hillbilly camo paint tommarow and the blazer... it also has tube bumpers that are 6 inch pipe with quater inch walls... built to go...
