I'll bring the Oreos. For the record, Jim and I have a mutual respect and are fine. Don't want anyone thinking we hate eachother or something. Continue on.Right now, I don't give a fuck what you think.
I appreciate the offer but I'll pass. I spent alot of time and money to put a V8 in, I don't want to go back to 4.0L power. Like I have said, it hasn't been for lack of effort, it's for lack of compromise and I'm ok with not going because of it. Plenty of parks to ride in.You'll find few people that have done more for the ORV community in Michigan than Jim.
Also here's your fix
Car Chemistry 3DI25R CC Inserts-Insert 3 Disk Mufflers Fits 2.5 in. Dia. Pipe CC Inserts-Insert 3 Disk Mufflers https://www.amazon.com/dp/B003V6O4C0/ref=cm_sw_r_apan_i_M5N92096H6HEDYZZDZES
Put two in my LQ4 and it quieted it down enough that I can have my 4 year old ride around with me. Probably restricts power a little but I don't have money on every ride so it's worth it.
Sent from my SM-G996U using Tapatalk
C'mon Ian, let's be real. He has zero interest in a solution, he just wants to bitch. Probably running 4.10 gears with 40s but worried a muffler is going to rob too much power 🤣You'll find few people that have done more for the ORV community in Michigan than Jim.
This x1000No matter how much effort you put in there is always some jackass with a " you should have done it this way " comment few will ever understand the effort you and others have put in but don't think for one minute it is lost on the rest of us. Those that Know,,,, Know and appreciate what we have.
RBB
My LQ4 made 620 rwhp last year, and has a muffler. It's on track to make 750 this year, and will still have a muffler.Also here's your fix
Car Chemistry 3DI25R CC Inserts-Insert 3 Disk Mufflers Fits 2.5 in. Dia. Pipe CC Inserts-Insert 3 Disk Mufflers Amazon.com: Car Chemistry 3DI25R CC Inserts-Insert 3 Disk Mufflers Fits 2.5 in. Dia. Pipe CC Inserts-Insert 3 Disk Mufflers : Automotive
RongC'mon Ian, let's be real. He has zero interest in a solution, he just wants to bitch. Probably running 4.10 gears with 40s but worried a muffler is going to rob too much power 🤣
Congratulations? You know it'd make more without it right? Turbo is a muffler? If purple is yellow what is green?My LQ4 made 620 rwhp last year, and has a muffler. It's on track to make 750 this year, and will still have a muffler.
This dudes stock NA one is gonna lose all the llamathrusts if he chokes down dem dere thunderin ponies though
People like this, want to bitch, they don't want a solution, he'll just move the goal post.
What muffler do you have now that doesn't keep it quiet enough... I've found several mufflers in the size you reference, yet no idea what to compare them to.Rong
Could you recommend a couple mufflers for a 3.5" diameter space 12" long that will pass the sound test please? I have mufflers, they just aren't quiet enough. Is reading this hard for people?
94 but you will get in at 96 with a warning.What muffler do you have now that doesn't keep it quiet enough... I've found several mufflers in the size you reference, yet no idea what to compare them to.
What is your decibal level currently?
Without looking it up, i assume the park is regulated to 94 or 96 db?
What distance at what rpm?94 but you will get in at 96 with a warning.
I don't have the tech description but it's the same format as used at Silver Lake. It's something like 18" @ 45* at 2500 rpm for a V8. There is a specific handbook and rpm for different 2 stroke engines and testing a V8 engine is different than a 6 cyl. Way more complicated than seems necessary but I guess it's all about controlling the low bass of a V8 vs the high rev brap of a 2 stroke because their sound carries different.What distance at what rpm?
There are so many low restriction options out there, but still nothing to compare it as of yet... I'm not even talking about feva, this is to gain my own knowledge. I'm in the quieter is better camp. Always have been, but want something with a little growl, has to be small, and low restriction because i have an idea for my new rig. Might not be a good one, but it will be fun!
It's kind of looking like those resonators might be a good choice, cheap and just add them until it passes.I don't have the tech description but it's the same format as used at Silver Lake. It's something like 18" @ 45* at 2500 rpm for a V8. There is a specific handbook and rpm for different 2 stroke engines and testing a V8 engine is different than a 6 cyl. Way more complicated than seems necessary but I guess it's all about controlling the low bass of a V8 vs the high rev brap of a 2 stroke because their sound carries different.
I had my buggy there for the first training sessions they did. Prior to the training, the non-trained people were just holding the meter close to my exhaust and I passed at something like 91. Then when we did the official test, I jumped to 104.I had a straight section in my exhaust of about 15" before my muffler and stuck in a couple straight through resonators. 2.5" duals all the way back to a common dual muffler. When you can look straight through them with no restriction, I was pretty sure they weren't going to do anything for me but it dropped it to 92.
All the straight piped people will be laughing at you from the top of the hill, that 7 hp would have made all the difference.All you silly kids with your V8s and automatics. My 4.0L has a catalytic converter, muffler, and resonator because I didn't want to make obstacles too easy with all that pesky horsepower.
I'm still riding that 4.0 train as long as I canAll you silly kids with your V8s and automatics. My 4.0L has a catalytic converter, muffler, and resonator because I didn't want to make obstacles too easy with all that pesky horsepower.
I'm running a full size full body rig...i need all the horse torques I can get 🤣All you silly kids with your V8s and automatics. My 4.0L has a catalytic converter, muffler, and resonator because I didn't want to make obstacles too easy with all that pesky horsepower.
