801 - 806 of 806 Posts
In Da Faaaaaace!!!
1988 YJ
Glad to see its working well for you.
How are you venting your axles/tcase/trans? Do they have individual filters or stock type jeep breather caps? Or do you route them all into a vented catch can?
Low Range Drifter
Discussion Starter · #806 ·
Hoses up to frame and those little factory style one way valves for diffs. Engine and gas tank have ebay&n filters. The trans and t-case loop up and over then have the check valves.
Pretty much. I’ve wiped away rust with WD40 and a green scotch bright. It’s on the barn and pretty muddy, so it should be a mess when I get to it.
