1 - 1 of 1 Posts
This is a lightweight full one piece fiberglass front clip for a jeep that is stretched. If you look behind the front tires in the pic you can see the rear section of the hood is approx 1 ft longer than a standard front clip. this isnt a home made job its made by power pro motor sports and are used in sand drag and mub bogger chassies to lenthen the wheel base and to cover the front wheels. a person could cut it shorter if needed or at a standard front length. there is a hole cut in it for a 14 inch air cleaner as seen in the pic. the headlights are not cut out there is a small crack in the passengers front fender but nothing that couldnt be repaired.
500.00
1 - 1 of 1 Posts
