1 - 1 of 1 Posts
nonsense
this is a rear axle out of a 97 jeep cherokee with a 5.2. it needs 1 axle i have the axle but it is a little bent. it needs the top and bottom spider gears,1 axle seal, pads and rotors, and i would put a pinion bearing in it. it growled when pulled but the gears look fine. they are 3.73. it is complete it has calipers abs wires trailing arms and sway bar on it sway bar has been cut however, and the steel brake lines were cut too but the hoses are fine. would be a easy fix and save money on just buying a new one. my number is 989 245 6063 my name is Tadd thanks
1 - 1 of 1 Posts
