1 - 8 of 8 Posts
broken
my wifes xj has a pin hole in it ,just out of reach of my welder. can i put jb weld on it or will it get too hot or stink?
thanks aron
Premium Member
it will burn off. stink for a while then just crust and come off. I tried it already LOL. They do make a high temp exhaust patch. That did work but ended up cracking off over time. Welding is the only permanent fix.
broken
Discussion Starter · #3 ·
haha figured some had tried it. thanks.
In Da Faaaaaace!!!
1988 YJ
they have exhaust putty at the local parts stores down the exhaust pipe isle. I used it a long time ago when I had the 4.2. The connection from the exhaust manifold to the down pipe always leaked so I used it there with good results.
Mudhowg's a ****
Used the putty this way before with results that lasted a very long time. Should be in the exhaust isle? Or you can drive out to Fenton, and I will weld it for free ???
hug life
x2 i use that junk my exhaust and it seems to hold up good.
Last Free Man
Is that until it blew up?:nana:
I wouldn't bother fixing it, just buy a big tube of JB weld and form your own manifolds out of it. :beerbang:
hug life
what blew up? my engine runs great. My header blew a hole in it last year, but i goober welded it (i learned from you) then stuck that exhaust putty on it. it has help up so far.
1 - 8 of 8 Posts
