1 - 16 of 16 Posts
· Registered
i need all the parts to convert my j10 from auto to a stick, i have the trans, just need the little pieces
Some things to consider........
What tranny you using?v8 or 6?........The v8 j truck manual trannys have a spacer block between the trans&bell,& a longer input shaft.The 6 cyl's don't,because they are mounted further back in the engine bay,because of their length.If you use a 6 cyl trans,the shifter will end up under the dash!I think I have an extra bellcrank mount bracket.
· Premium Member
I have a complete 1981 J-10 manual trany 6 cylinder. Still completely together. Take whatever you need excluding the trany and t-case for $100 you remove. I will even let the steering column go if you need that. Or just come get the complete truck take what you need and sell the rest. $650
1 - 16 of 16 Posts
