1 - 4 of 4 Posts
97TJ, 33x12.5x15 mud terrains, AGR superbox 2 and matching AGR pump with redline synthetic power steering fluid.
it's a manual tranny, but the radiator has the tranny cooler option build into it. so would it be worth it to hook the power steering into the tranny cooler and use it as a power steering cooler??? like would there be a noticable difference, or other benefit, or should i not waste my time???
hug life
im wondering if a trans cooler could take the pressure? id like to know the answer to that one.
The cooler is plumbed on the low pressure side, theres no issue there....
many people run it through the trans cooler on the radiator, with no ill effect. But it does WARM your fluid, so its not as effective as a seperate trans cooler.
1 - 4 of 4 Posts
