1 - 5 of 5 Posts
Discussion Starter #1 (Edited)
Everything listed below is $200 obo, i have all the original boxes and receipts this system was installed by best buy, used only a few times and i really have no need for it anymore. so someone is going to get a great deal on this system. It is all well cared for and has been stored inside.
What is included,
amp, subwoofer, wiring kit, and a add a amplifier kit for stock radios.
$200obo or trade
looking to trade for a canoe or work out equipment like a bowflex or something like it.
Thanks for looking
Kris Stephens or Brandon Stephens
248 969 9903 home phone
248 494 2190 cell phone
Insignia Mono Amp
1200 watts
Class D
# 150W RMS output @ 4 ohms with 1% THD
# 225W RMS output @ 2 ohms with 1% THD
# 400W RMS output @ 1 ohms with 1% THD
# Adjustable 40-250Hz low-pass crossover; 15-40Hz subsonic filter
# High-speed digital circuitry with fully regulated PWM power supply
# Bridging synchronization
# System distress indicator
# Remote dash mount low-level gain control with cable; heavy-duty nickel-plated power and speaker terminals
# Sensitivity: 200mV to 8V
# Output impedance: 100 ohms
Here is the link for more details
http://www.bestbuy.com/site/olspage....=1168042687920
Insignia 12" Subwoofer
1800 Watts
Product Features
# Handles up to 1800W peak power (600W RMS)
# Polypropylene cone with large foam surround and dual black poly-cotton spiders; woven tinsel lead through spider
# 2" BASV dual 4-ohm voice coils
# Chrome push terminals
# Rubber gasket
# Die-cast aluminum basket and gray finish with diamond-cut pattern
# Sealed box: 1.2 cu. ft.; ported box: 2.0 cu. ft.
# One 4" x 8-3/4" port
# Tuning frequency: 40Hz
# 200 oz. magnet structure
For more info
http://www.insignia-products.com/pc-...subwoofer.aspx
12" Bandpass box
# Sealed and ported
# 2 ports
SoundGate
Universal Line Output converter.
High Performance Line Output Converter/Factory Subwoofer Retainer
The LOCX is a 2-channel transformer-based line output converter that raises performance and feature bars to a new level. Designed to be installed after any of today's high wattage factory amplifiers. The LOCX will also allow you to retain your factory subwoofer when installing an aftermarket radio.
More Info
http://www.soundgate.com/index.php?r...usereferrer=1&
1 - 5 of 5 Posts
