I have a K5
1.2K views 27 replies 4 participants last post by  Lousypirate
#1 ·
I have a 1988 Blazer
#15 ·
Rear axle is still about 1” behind where it should end up. But got the rear leaves tossed in place, had to turn down the bushings a bit to fit right. This should be pretty close to ride height. Hoping to get the rear slider boxes bolted to rear eye and crib them up with some weight on the back to get an idea for mounting. Then i’ll make the slider boxes a bolt on so i can add shims in the future if i feel the need to lift the back some.
#18 ·
On ground with suspension loaded
door sill 29”, bed rail 59.5”, although i expect that to settle some
cribbed up the slider boxes to sort out brackets, going to add a touch more rake for adding fuel, roll cage, soft topper, whatever going in bed and rear seats
also making the sider boxes bolt on so i can add shims if i ever need to lift it further.
#23 ·
got the slider boxes mounted up, need to finish welding the saddle in. Currently the bedrail is around 1.5° raked up without gas tank, hitch, or rear bumper. Guessing that will be a lot closer to 0 once installed and filled.
Took some extra time to make them bolt on so i can shim the brackets down if needed once interior stuff is added and everything settles.
Will be on to interior and a rear hitch. Still mentally avoiding the wiring and shock mounting for the time being.
