1 - 20 of 29 Posts
NO RELIGION WAT!
His jeep was making weird noises so I pulled the rear diff cover off.......
1st clue something was wrong.......no diff fluid
2nd clue was ring gear would move up and down
3rd clue is the pic
So I replace the diff cover with a new and improved diff cover and refilled the diff fluid and sent him on his way. Best $250 I ever made :tonka:
huh?
NO RELIGION WAT!
Discussion Starter · #9 ·
If you look close there is a hole punched in the diff cover in the upper right hand corner. I didn't charge for the new diff cover. :thumb:
Playing Possum
Looks like you have a future as an automotive mechanic if you ever tire of cutting out keychains from metal. :tonka:
NO RELIGION WAT!
Discussion Starter · #15 ·
so did you fix the ring gear problem
unfortunately no:( at the time we had no means of pressing off or on the bearings. If I had not stuck my finger in his rear end he would of eventually have exploded it. :d:
I did make a kewl find though. United autoparts on Gratiot will press off and on new bearings for $16 :thumb:
1 - 20 of 29 Posts
