1 - 20 of 25 Posts
· Desert Rat
I have a small ditch behind my lot. I've heard mineral oil will put a film on the surface that the skeeter larva can't get through for air.
Any other suggestions?
· i don't much care for you
someone told me that certain soaps and detergents are the "green" way to to kill the larvae without affecting anything else. just passing it along.
· Registered
The BTI briquets will work well as long as they are just larva.
If you have Pupa, you are going to need to use a oil to leave a film becasue pupa do not eat so the BTI will do nothing to kill them, you need to suffocate them.
I work for Mosquito Control in my county and we use a petroleum based additive with basically mineral oil. It dissapates in 24-36hrs, doesn't hurt anything big enough to break the surface tension.
Other than that if you can get your hands on something called Abate. when the ditch drys up if it ever does throw some of that in there ever so many feet and when it floods it will pretreat the ditch and you won't have any mosquitos.
· Desert Rat
Discussion Starter · #6 ·
so the mineral oil story is true?
Cool. Do you have to spray it or can you just pour it?
· Buy a Fiat! Save the UAW!
Spray it in the water. Pouring it in won't do anything
you need to go back to science class. oil is lighter so it floats no matter what. he can use old corn oil or any other cooking oil also. its just a cost factor.
dump it in. at the worst you will save time battering your frog legs
· NO RELIGION WAT!
Geez. Just maybe she prefers it being sprayed on verses having it dumped on making a mess.
· expert jeep disassembler
i wonder if spraying it coats the whole area compared to dumping it which will stay bunched up in one area. just taking a guess.
1 - 20 of 25 Posts
