1 - 19 of 19 Posts
hicktown
ok i need new u joints which ones are better i have a u joint out on my yj so the drive shaft fall off
hicktown
Discussion Starter · #3 ·
realy i dont think so not reuseing u joints but i was wordaring if sealed ones were more reliable
The Man Myth And Legend
evry wone i tlak 2 cay sealed are bitter caws thres no driwlled whole 2 macke
them week...butt evwyone hass theer own opinton
broken
x2
Not if you wrap the joint caps in teflon tape and tin foil.
Banned
i suggest you lay off the lead based paint chips, even though tehy bring teh tastee.
Not Right!
x12565685
Also, super strength greasable u-joints are available, they have the zerk in the end of the cup vs. the cross (which does weaken the casting of the u-joint).
x12565685
So you don't use teflon tape and tin foil?:confused:
Fucking Zen as Shit
WILL YOU PLEASE FUCKING DIE ALREADY.
You can't type, spell or use 1st grade grammer.
So please die or go away
Banned
WTF is grassable? Do you need to fertilize, cut and water it?
cant you understand plain english?? grassable is when you can regrass something with your grassgun.
1 - 19 of 19 Posts
