1 - 10 of 10 Posts
Chillin with the top off.
Yep, I need a amc v8 to drop in my cj7. My 390 runs like a raped ape but has no oil pressure.. Put a wear plate in it and it did not make a difference.. What ya got?
HAND-ME-DOWN Racing
I've got a rebuilt 343 w flat tops, holley intake 401 ported 58cc heads w/triple valve springs little better than 401 stock cam rhodes lifters. cRank drilled to fit auto or manual trans. Would take 401 or 390 parts on trade + $$.
616-638-1884
Used to be that you could replace the spring in the oil pump to increase the oil pressure. the spring regulates the oil pressure=stiffer spring rate. This amc book i have says you can increase your oil pressure by machining off .003 to .005 thou off the bottom of your aluminum housing.(where your "plate bolts on.) To know how much you can shave off is to plastigage how much clearance you have between the gear and the plate. Anyways.....do you want to sell your 390?$$
Discussion Starter · #8 ·
I guess I still need an engine.. My deal fell through..
Im Rick James Bitch
We have a Vortec 5.3L ready to drop in. everyone heard it run last week at the Jeep Cruise. Call Jon at 616-392-FIXX.
1 - 10 of 10 Posts
