1 - 8 of 8 Posts
Uggh
01 teejay will not crank there is
~ power at the starter from the battery
~ power to the solenoid
~ starter works fine on the bench
Ideas I've never had an Issue like this
thanks in advance
Uggh
Discussion Starter · #4 ·
Well, do you have a ground from your engine block to the body/frame/battery?
Uggh
Discussion Starter · #6 ·
I just checked the grounds I'm heading to mazza to buy a ton of 6 ga and redo all the main wires
I hope it works
Can't lose with 42s
Gotta be a ground problem dood
You say theres 12V on the signal wire when you have the key in the start position?
Uggh
Discussion Starter · #8 ·
yes sir i'm replaciong the engine ground next
1 - 8 of 8 Posts
