1 - 9 of 9 Posts
i have a 727 trans that is in need of a rebuild no likeage or anything or converter just trans and all the guts , fluid was black and major slippage good for somthing 50$ or a cb or some lights trades welcome
Discussion Starter · #2 ·
any one would be a good core or rebuild i think it had a burnt torque converter , has a good trans pan if any body needs one make offers just sitttin in the garage
Was it a 4x4 tranny? Does it still have the adapter from the main case to the t-case? Is the bolt pattern for the t-case the round 6-bolt style as needed for an NP231 or D300? Is the output shaft 23spline?
I will be gone Fri the 20th and be back the 30th. If the answers are yes to those questions, I will take it, burnt fluid and all..... :) I will check back when I get back. Thanks!
Discussion Starter · #4 ·
it has the adapter but the t case was a 229 not sure if it was the same bolt pattern and i think its a 24 spline
1 - 9 of 9 Posts
