1 - 14 of 14 Posts
Bluminade Has Arrived
need a ford np 203 t case must be ford. or 203 205 doubler for c6. i have a few things willin to trade for t case. a 78 f150 w no engine trans or tcase, truck has 6 or 8 in suspesion lift with rearched leaves in the rear. a 351 m. a set of 15x8 8 bolt wheels that are sandblasted. or will pay cash for t case
I have a tcase out of a 86 bronco it was attached to a c-6. i think it a 205. I can get pics if interested. I may be interested in that 78 do you have any pics of it.
Big Block Ranger
The tcase he is looking for will be about of an early 70's 4x4, and will be a fulltime 4WD case. It is huge, heavy, and all cast iron except for a couple seal retainers.
Big Block Ranger
bluminade, you might want to give this CL ad a shot. I know he says np208 in his ad but it is more likely that he doesn't know what he has than someone actually put a 208 in a 1971 truck. Either way, its worth a phone call.
http://grandrapids.craigslist.org/pts/982255257.html
Axle Guru Extraordinaire
Have a chevy reduction box without a input for $25. Works good for clocking it up 90 degrees for a flat bottom.
Discussion Starter · #12 ·
yes the big heavy 203 from a ford is what i am looking for. i must have the 31 spline ford input shaft .
1 - 14 of 14 Posts
